Same PPPOE session ID for different sessions
joselopez
Hi All,
We have a setup with a central router and a remote router. We want to establish 2 PPOE session to the same remote site.
We have created 2 dialer interfaces and each interface dialer is attached to 2 different Lan interfaces.
We can not establish the 2 sessions simultaniously, because we see with the "sh ppoe session" the same session ID for each session.
Uniq ID PPPoE RemMAC         Port              VT VA         State
            SID      LocMAC                               VA-st          Type
N/A     1           mac x            G0/0               Di1 Vi2         UP
                        mac y                                                     UP
N/A     1            mac x           Gi0/1              Di2 Vi3          UP
                         max z                                                    DOWN
Can anyone help me with this issue?
Thank you,
José
Hello Jose,
I am somewhat concerned about seeing the pppoe enable group global in your configuration. They make your router behave like a PPPoE concentrator itself. I suggest removing them, just to be sure they do not interfere with the proper operation of your PPPoE client configuration.
I advise caution here: as soon as you enter the no pppoe enable command on your Gi0/0 and Gi0/1, the pppoe-client configuration will be removed as well, surprisingly enough. Therefore, after you remove the pppoe enable group global commands, you will need to put the pppoe-client dial-pool-number X command back. Be aware that this will lead to a loss of connectivity until the PPPoE client reestablishes its session with the remote site.
Best regards,
Peter
adnane dakna
can you post the both config (Server and client pppoe)
Hello adnane,
I don't have the config f the server but see below the config of the pppoe client.
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname test
boot-start-marker
boot system flash c1900-universalk9-mz.SPA.151-4.M4.bin
boot-end-marker
logging buffered 50000
enable secret 5
no aaa new-model
clock timezone gmt 1 0
clock summer-time gmt recurring
no ipv6 cef
ip source-route
ip cef
ip vrf Internet
rd 65001:1000
route-target export 65001:1000
route-target import 65001:1000
ip dhcp excluded-address 192.168.3.1
ip dhcp excluded-address 192.168.3.254
ip dhcp excluded-address 192.168.3.11 192.168.3.16
ip dhcp excluded-address 192.168.1.3
ip dhcp excluded-address 192.168.1.14
ip dhcp excluded-address 192.168.1.13
ip dhcp pool Shell
import all
network 192.168.3.0 255.255.255.0
lease 5
ip dhcp pool Internet
import all
vrf Internet
network 192.168.1.0 255.255.255.240
domain-name test.be
dns-server 195.130.130.11 195.130.131.11
default-router 192.168.1.14
lease 5
no ip domain lookup
isdn switch-type basic-net3
license udi pid CISCO1921/K9 sn FCZ1610900U
license boot module c1900 technology-package securityk9
license boot module c1900 technology-package datak9
username codenet password 7
redundancy
ip tftp source-interface Loopback2
policy-map SHAPE_VDSL_VPN
class class-default
  shape average 1000000
policy-map SHAPE_VDSL_Internet
class class-default
  shape average 512000
interface Loopback1
ip vrf forwarding Internet
ip address 10.10.19.66 255.255.255.240
ip nat inside
ip virtual-reassembly in
interface Loopback2
ip address 84.199.222.158 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
pppoe-client dial-pool-number 2
interface BRI0/0/0
ip address negotiated
ip nat outside
encapsulation ppp
dialer idle-timeout 300
dialer string 1661032932940
dialer load-threshold 10 outbound
dialer-group 10
isdn point-to-point-setup
ppp pap sent-username
BU_CEBRUSHS01@VPRN_2035
password 7 00081F550C6818555F265C1F0A492B
interface FastEthernet0/1/0
switchport access vlan 10
no ip address
no cdp enable
interface FastEthernet0/1/1
switchport access vlan 20
no ip address
no cdp enable
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface Vlan1
no ip address
history BPS all
interface Vlan10
description ### VLAN IVPN ###
ip address 192.168.3.254 255.255.255.0
ip access-group 100 out
ip nat inside
interface Vlan20
description ### VLAN Internet ###
ip address 192.168.1.14 255.255.255.240
ip access-group 101 out
ip nat inside
interface Dialer1
bandwidth 100000
ip mtu 1492
ip flow ingress
ip flow egress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
load-interval 30
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp ipcp route default
no cdp enable
service-policy output SHAPE_VDSL_VPN
interface Dialer2
bandwidth 100000
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
service-policy output SHAPE_VDSL_Internet
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 50 interface Loopback1 vrf Internet overload
ip nat inside source static 192.168.1.3 10.10.19.65 vrf Internet
ip nat inside source static 192.168.1.13 10.10.19.67 vrf Internet
ip nat inside source static 192.168.3.11 10.74.9.193
ip nat inside source static 192.168.3.12 10.74.9.194
ip nat inside source static 192.168.3.13 10.74.9.195
ip nat inside source static 192.168.3.14 10.74.9.196
ip nat inside source static 192.168.3.15 10.74.9.197
ip nat inside source static 192.168.3.16 10.74.9.198
ip nat inside source static 192.168.3.1 10.74.9.202
ip route 0.0.0.0 0.0.0.0 BRI0/0/0 254
ip route 10.74.9.192 255.255.255.240 Vlan10
logging source-interface Loopback99
logging 195.130.131.217
logging 195.130.148.25
access-list 1 permit 195.130.131.216 0.0.0.7
access-list 1 deny   any log
access-list 40 permit 10.74.128.0 0.0.7.255
access-list 40 permit 195.130.131.216 0.0.0.7
access-list 40 permit 192.168.248.0 0.0.7.255
access-list 40 permit 192.168.243.0 0.0.0.255
access-list 40 deny   any
access-list 50 permit 192.168.1.0 0.0.0.15
access-list 100 permit tcp any host 192.168.3.1 established
access-list 100 permit tcp any host 192.168.3.1 eq 65000
access-list 100 permit udp any host 192.168.3.1 eq 65000
access-list 100 permit tcp any host 192.168.3.1 eq 3389
access-list 100 permit udp any host 192.168.3.1 eq 3389
access-list 100 permit tcp any 192.168.3.0 0.0.0.255 eq 2150
access-list 100 permit udp any 192.168.3.0 0.0.0.255 eq 2150
access-list 100 permit tcp any 192.168.3.0 0.0.0.255 eq 28784
access-list 100 permit udp any 192.168.3.0 0.0.0.255 eq 28784
access-list 100 permit tcp any 192.168.3.0 0.0.0.255 eq 2200
access-list 100 permit udp any 192.168.3.0 0.0.0.255 eq 2200
access-list 101 permit tcp any host 192.168.1.3 eq 90
access-list 101 permit udp any host 192.168.1.3 eq 90
access-list 101 deny   tcp any host 192.168.1.3
access-list 101 deny   udp any host 192.168.1.3
access-list 101 permit tcp any host 192.168.1.13 established
access-list 101 permit tcp any host 192.168.1.13 eq www
access-list 101 permit udp any host 192.168.1.13 eq 80
access-list 101 permit tcp any host 192.168.1.13 eq 443
access-list 101 permit udp any host 192.168.1.13 eq 443
access-list 101 permit tcp any host 192.168.1.13 eq 5900
access-list 101 permit udp any host 192.168.1.13 eq 5900
access-list 101 permit tcp any host 192.168.1.13 eq 3668
access-list 101 permit udp any host 192.168.1.13 eq 3668
access-list 101 permit tcp any host 192.168.1.13 eq 5869
access-list 101 permit udp any host 192.168.1.13 eq 5869
access-list 101 deny   udp any host 192.168.1.13
access-list 101 deny   tcp any host 192.168.1.13
access-list 101 permit ip any 192.168.1.0 0.0.0.15
dialer-list 10 protocol ip permit
no cdp run
the config seems to be normal , post result of "debug pppoe events "
Hello Jose,
Best regards,
Peter
