same subnet between WAN link
Vijendra Ramdoo
Thanks to give your insights on the below issue.
I need to route the same subnet on two routers (PC0 to communicate with PC1 and vice versa).
Host routes seem to do the trick, but is there any way to route the whole subnet? There are a lot of hosts in those subnets.
Thanks for all your help
Vijen
cadet alain
you can use static nat on both routers.
Alain
cadet alain
Alain
Hi Alain,
Thanks for your reply.
However, I guess static NATs would be one-to-one NATs.
Maybe i'm getting it wrong. Could you please provide an example so that I may better understand how to do the NAT?
Cheers,
Vijen
