sample BGP Configuration
acharyr123
Level 3
Level 3
This is basically a call center setup where all external voice connections will get terminated into edge switches.
We need to run iBGP between ASA5540-AIPSSM, 6500 switch having FWSM modules.
eBGP will run b/w ISP & the Internet Routers, rest will be on iBGP.
Can someone help with a sample config for achievening the same??
prasanta.ray
Dear acharyar123,
Please find the below configuration that you can do for both of your internet routers.
router BGP ASN
no synchronization
no auto-summary
bgp log-neighbor-changes
neighbor x.x.x.x remote-as ASN
neighbor x.x.x.x description SIFY_RF_PEERING
neighbor x.x.x.x update-source x.x.x.x neighbor x.x.x.x version 4
neighbor x.x.x.x default-metric 200 #MED#
neighbor x.x.x.x prefix-list zz out
neighbor x.x.x.x prefix-list zz in
neighbor y.y.y.y remote-as ASN
neighbor y.y.y.y description for ibgp
neighbor y.y.y.y version 4
neighbor y.y.y.y update-source t.t.t.t #LAN#
Network 202.x.x.x 255.255.255.248
Network 210.x.x.x 255.255.255.0
Network 210.x.x.x 255.255.255.252
Network 221.x.x.x 255.255.255.240
Network 221.x.x.x 255.255.255.248
Network 192.192.16.0 255.255.255.240 # LAN#
ip prefix-list zz deny LAN
ip prefix-list zz permit 0.0.0.0/0 le 32
ip route 0.0.0.0 0.0.0.0 x.x.x.x
Also to track for redundency you can use SLA Tracking:-
standby 1 track 22 decrement 12
Ip sla 11
Icmp-echo < to the Primary interface to which tracking is done> source-interface Gi0/0
frequency 5
ip sla schedule 11 start-time now life forever
Track 22 rtr 11 reachability
also before you configure IP Sla configure HSRP on the ethernet /gig interface.
Please let me know if you require any more thing
Thanks and Regards
Prasanta
