Script
amansoi_5
Sir,
Can we get a script wherein we can check the ISDN line of any site ?
That is the router has been configured with ISDN as backup & leased line as primary media . We just want to check the ISDN line .
In normal procedure we login into router and remove backup & check ISDN by entering isdn test call followed by other end ISDN (PRI ) number ..
We have got about 1000 sites wherein this practice becomes very tedious..
So to avoid this we are looking for a script where in enable password of router along with other necessary config is entered in the script for testing ISDN .
rgds,
aman
scottmac
Level 10
Level 10
Find someone that knows Perl.
There is a module called :Net::Telnet, and another module called Net::Telnet::Cisco. These are libraries of routines you can call for easier scripting.
Another possibility might be to use "expect"; expect is a fairly sophisticated query/response scripting system, available for free and runs on *nix or Windows.
There are some other scripts apps for Windows ... but their names escape me at the moment.
Scripting on the *nix side could also be a shell script (sh, bash, ksh, zsh ...), Python, Ruby, Tcl ...
The preferred language for this would probably be Perl (free: www.activestate.com for Windows, included in most *nix/BSD distributions).
If you can't find a programmer, then 'expect' would probably be your best bet (http://sourceforge.net/projects/expect) - it's also well docuemented, up to, and including, O'Reilly books.
Good Luck
Scott
