SDM launching problems....
acomiskey
Level 10
Level 10
Having trouble getting SDM to work on an 1841 router.
SDM version 2.4.1
Router Version 12.3(8)T6
Win XP
IE and Firefox
Java Runtime 5 update 10
The application begins to load then freezes on the following message.
"Please wait while the SDM is loading the current configuration from your router
Populating modules... - NAC"
Any ideas welcome. Thanks.
mohammedmahmoud
Level 11
Level 11
hi,
Make sure that you've permitted it in the Win Firewall, and then before launching SDM clear the browser cache.
HTH,
Mohammed Mahmoud.
Thanks Mohammed, I rolled back to SDM v. 2.2 and was able to connect through firefox. Still no luck with IE.
Unfortunately, I'm having bigger issues at the moment.
Hi Adam,
You are more than welcomed :) and good luck with your problems, and anyway here you are the list of caveats with version 2.4.1:
http://www.cisco.com/univercd/cc/td/doc/product/software/sdm/rlsnotes/sdmr241.htm#wp92180
BR,
Mohammed Mahmoud.
