Second VPN connection
Tazio4436
I am testing a new network and I need to create a site to Site VPN connection.
My production network already has a Site to Site VPN connection.
Site 1 has a Cisco 2911.with Lan 10.88.X.X/24 and 192.168.1.0/24
Site 2 has a Meraki with Lan 10.35.X.X
The VPN between these 2 site are working fine and they are the production site.
Now on site 2 I have another Meraki but Lan is 10.21.X.X.
I want to create a VPN between the second Meraki on site 2 and site 1.
Note that site 1 has 1 ISP and site 2 has 2 ISP and each Meraki have 1 different ISP.
I have configured the Meraki on site 2 and did some basic configuration on cisco 2911 on site 1 but now i am not sure if I can add some more commands on the outside interface as it has already beren configured with some commands for VPN 1.
Please see attached drawing for more information.
Some input will be highly appreciated from anyone.
Tazio
6 Accepted Solutions
omz
Use the same crypto map already on the outside interface. You can add another numbered entry to the crypto map with different transform-sets and match ACLs.
crypto map CMAP 10 ipsec-isakmp
match address 101
set peer 2.2.2.1
set transform-set TSET
crypto map CMAP 20 ipsec-isakmp
match address 102 set peer 3.3.3.1 set transform-set TSET2
https://community.cisco.com/t5/vpn-and-anyconnect/multiple-crypto-maps-on-single-outside-interface/td-p/2373092
https://community.cisco.com/t5/vpn-and-anyconnect/multiple-vpn-and-crypto-maps/td-p/1830689
Hope this helps.
Giuseppe Larosa
Hello Tazio,
the crypto map applied to the outgoing interface on the C2911 can use multiple clauses / blocks.
Each block refers an IPSec peer that must be different and an ACL that must be different and allows traffic from internal subnets to a different destination.
The transform sets can be the same or different.
each crypto map block has a sequence number and they are processed in order
Hope to help
Giuseppe
This is what i added on the Cisco 2911.
There is no issue on the Meraki side.
crypto isakmp policy 20
enr aes
authentication pre-share
crypto isakmp key VPNKEY address 38.32.57.158
crypto map VPNSET 20 ipsec-isakmp
! Incomplete======>I don't know what is missing ?
set peer 38.32.57.158
set transform-set VPNSET
match address 105
crypto ipsec transform-set VPNSET esp-aes esp-sha-hmac
mode tunnel
This is what I have on the outside int of the Cisco 2911
interface GigabitEthernet0/1
description OUTSIDE
ip address 216.123.3.30 255.255.255.240
ip access-group OUTSIDE_IN in
ip mtu 1492
ip virtual-reassembly in
duplex auto
speed auto
no cdp enable
end
What I wanted to add on the outside interface are:
crypto isakmp VPNSET
access-list 105 permit ip 10.88.0.0 0.0.0.255 10.21.0.0 0.0.7.255
already have ip route as ip route 0.0.0.0 0.0.0.0 216.123.3.17
Your help will be much appreciated.
Tazio
Hello Tazio,
my understanding was that you had already a crypto map applied to the outgoing interface and you just wanted to add a second block/clause the existing crypto map.
Can you confirm what is the scenario ? the first VPN connection is exiting the same interface or another interface on your side? The network diagram makes me think you have both VPNs terminated on IP 216.123.3.30.
if so the crypto map should be already applied to your outgoing interface and you are just adding a second block for Meraki2 device.
Please note that the access-list OUTSIDE_IN may need to be updated to allow traffic coming from host Meraki2 38.32.57.158.
Can you post the configuration of both blocks of the crypto map?
Hope to help
Giuseppe
Hi Thank you very much for your support and help.
Both Meraki (Production and Test) will need to create VPN with same and single interface on Cisco 2911 which is the  interface GigabitEthernet0/1.
The Lan blocks for the side where the Cisco 2911 are 10.88.0.0/24 and 192.168.1.0/24.
The Lan side for the Production Meraki is 10.35.8.0/22
The Lan side for the TEST Meraki is 10.21.64.0/21.
Please see attaced the show run for Cisco 2911.
Tazio
Hello Tazio,
OK I report here the current crypto map configuration
crypto map remap 1 ipsec-isakmp
set peer 184.94.68.98
set security-association lifetime seconds 28800
set transform-set VPN-MY-Meraki
set isakmp-profile VPN_565-Meraki
match address NETWORK_88-565
reverse-route
crypto map remap 10 ipsec-isakmp dynamic remap
You need to add a second block before the final line with all parameters related to the TEST meraki
crypto map remap 5 ipsec-isakmp
set isakmp-profile VPN_Meraki_Test
match address NETWORK_to_TEST_Meraki
reverse-route
define all the needed object before the ACL NETWORK_to_TEST_Meraki and the isakmp-profile and crypto key-ring.
crypto keyring VPN-Meraki_Test
pre-shared-key address 38.32.57.158 key <test-password>
crypto isakmp profile VPN_Meraki_Test
match identity address 38.32.57.158 255.255.255.255
And the ACL
ip access-list extended NETWORK_to_TEST_Meraki
permit ip 10.88.0.0 0.0.0.255 10.21.64.0 0.0.7.255
permit ip 192.168.1.0 0.0.0.255 10.21.64.0 0.0.7.255
Hope to help
Giuseppe
7 Replies 7
omz
match address 101
set peer 2.2.2.1
Hope this helps.
Giuseppe Larosa
Hello Tazio,
Hope to help
Giuseppe
enr aes
match address 105
mode tunnel
description OUTSIDE
ip mtu 1492
duplex auto
speed auto
no cdp enable
end
Tazio
Hello Tazio,
Hope to help
Giuseppe
Tazio
Hello Tazio,
reverse-route
reverse-route
And the ACL
Hope to help
Giuseppe
Thank you very much for your support.
I did not configure the new VPN connection yet but will do it soon and I will let you know about the outcome.
Thanks and regards
Tazio
