selective rtp header compression
atou
I want to implement RTP header compression but just for some ranges. I tried with Parent and child policy-maps but doesn't work.
In attachment you can find the config. I guess I can use the same config for the other side when I change the access-list or not?
Kind regards,
Anthony
cdusio
Level 4
Level 4
It looks like this will work. I set it up in my lab, why do you think it's not working?
When I add the rtp header compression command, I can't use the Voice_Compression policy-map.
When I remove the rtp header compression command I can use the Voice_Compression policy-map in the Voice policy-map.
Do you know of a solution to my problem to only do rtp header compression for a specific rangez of IP's?
