Serial interface quiery
CSCO10758684
Hai,
I have a dout regarding the output of serial interface.Below output ...Its mentioned Availiable Bandwidth 88 Kbps.What does this exactly means.Is it some thing related to T1/E1 max bandwidth which an interface can use. ...Please help me regarding this
Output queue: 0/1000/64/90 (size/max total/threshold/drops)
Conversations 0/245/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 88 kilobits/sec
5 minute input rate 156000 bits/sec, 56 packets/sec
5 minute output rate 52000 bits/sec, 51 packets/sec
lgijssel
Level 9
Level 9
Often, one link says more than a 1000 words...
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080103eae.shtml
regards,
Leo
josephchacko79
i think this is CIR
Hai,
Thanks for your update ...I think CIR is comming in Frame relay concept..I ve changed Availiable bandwith using the command Max-reserved-Bandwodth 100 % but ..the changes i observed is from 88 Kbps it went to 648Kbps ...still didint understand ...the same ...Can some one help me
