serial to RJ45 int
saidfrh
I have a home lab with 2501 routers. I just picked up a 1721 router with 1 DSU T1 WIC card, RJ45 port. How can the serial port on the 2501 physically connect to the RJ45 WAN port on the 1721 router?
5 Replies 5
paolo bevilacqua
You need a T1 DSU with serial interface (most common is V.35) for this. Sometime incorrectly called "T1 modem". There are many makers and models, should be easy to find used on the leading auction site.
You can achieve your goal using following setup
PC---Router2501--(v.35 to RJ-45 converter)---Router1721--PC
For above setup you need
1) One DB-60 to V.35 cable.(WIC-1T has DB-60 Port so connect DB-60 end to 2501 router's Serial Port and another end to coverter)
2) V.35 to RJ-45 Converter(For Ex:- D-Link FE2VL)this type of coverters has V.35 input Interface and RJ-45 Output interface.
this will solve your issue.
Best Regards,
Sagiterian.
Sagiterian,
May you have incorrectly typed D-Link 'FE2VL'? I could not find the above on Dlink's web site.
Thanks.
Said
Hi Said,
Try to search "DIC 2000FE2VL" hope this will help you in finding right stuff.
Sagi.
The device mentioned appears to support E1 only, while T1 is needed in this case.
Common makers are adc kentrox, telindus, and a lot of no-name boxes.
