Seriale Cable Selection
Jacob Samuel
I have ordered for a Cisco 2811 Routers with 1 Port Serial Interface Card (WIC 1T Type Card) but the cable to connect to the modem i mentioned was CAB-SS-V35 type cables (10 feet Male Smart Serial Cable). Later I found that WIC 1T Card use CAB-V35 (normal) cable only. Smart serila have 29 Pin and V35 60 Pins.
Which means I can not use CAB-SS-V35 Serial Cable with WIC 1T card. Am I right ? Please add your comment asap.
Jacob Samuel
Danilo Dy
No you can't. You need to use CAB-V35.
How did you made the mistake? Is it because this link http://www.cisco.com/en/US/products/hw/routers/ps274/products_data_sheet09186a0080091b8b.html that supposed to show WIC-1T from this link http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html didn't actually show it?
In future, use Router Guide http://www.cisco.com/application/pdf/en/us/guest/products/ps5855/c1031/cdccont_0900aecd8019dc1f.pdf which clearly say DB60 for WIC-1T and Smart Serial for WIC-2T (see page 155)
CAB-V35 has been in the market for so long. Im sure you can find someone who is willing to exchange your CAB-SS-V35 to CAB-V35 with no charge :)
Dandy
Hi Dandy,
Thakns a lot for the link and information.
There was some other devices also which use WIC 2T card so think some mistake in the copy paste.
regards
Jacob
