07-10-2014 08:01 AM - edited 03-04-2019 11:19 PM
kindly find the attached file . is cisco router series 800 can support multihoming to internet , one is back to ather ?
i want to track connectivity to internet by pinging a certain real ip through ETH0 , if it fail change default route to Eth1 to keep connectivity to internet is up
if series 800 dont support that configuration what model can support that ?
07-11-2014 10:45 AM
Hello.
This might help: http://docwiki.cisco.com/wiki/NAT_failover_with_DUAL_ISP_on_a_router_Configuration_Example
07-14-2014 02:28 AM
Hello Vasilii ,
first thanks for your replay but this solution dont support if Br0 of ADSL R1 get down .
i want to track connectivity to internet on interface Eth0 . so my question if there are model in cisco router series 800 support that command of track and can take action to send me an email if connectivity to internet fail through Eth0 ? if not what model of router can support command of
1- tracking interface
2- send an Alarm email if connectivity fail .
07-14-2014 03:43 AM
Hello.
You may use Event manager to send email.
Interface tracking may be done per syslog message or interface state.
