SERVER REQUEST TIMED OUT
adhityakarthik
hI
i HAVE SERVER TO CONNECTED TO BLADE SWITCH, NOW I AM VERY FREQUENTLY GETTING REQUEST TIME OUT FROM THIS SERVER.
I HAVE CHECKED LOGS IN THE SWITCH, I COULDNT ABLE TO FINE ANY LOGS TO THAT PARTICULAR PORT/VLAN WHERE THIS SERVER IS CONNECTED
cOULD YOU PLEAES SUGGEST WHAT IS NEXT COURSE OF ACTION FOR ME
REGDS
aDHI
ohassairi
Level 5
Level 5
check logs in windows eventlog. may be you will find server disconnected from lan...or other pbs
Check the server logs
Run command on the port to check the counters of the port
Shinterface Fast x/x see if there are any drops
Check the duplex settings on the server and switch port
Check the cable as well between the server and switch
Possibly the problem will be with duplex setting similar issued happened with me as well in past
