setting up a route server
dhalevi
hi all,
Is it possible to setup a BGP route server on a cisco router?
Is it possible to have the "route server" then not insert its AS into the AS Path?
many thanks!
Laurent Aubert
Yes it's possible. Easiest way is to create static route pointing to null0 and to redistribute them into BGP where you can change the NH based on your needs. Also if you are using iBGP session, no AS will be added.
Laurent.
