Join Customer Connection to register!
1837
rafrancis
Beginner
SFP For ASR1006 -- Will GLC-LH-SM Work????
I have an ASR1006 running IOS-XE 15.0 ADVENTERPRISE, so I would like to know if the SFP (which I got from another router) with part number GLC-LH-SM would work in it  -- it's for a Single Mode connection.  I ordered part number SFP-GE-L= already, but it has not arrived yet so I just want to know if GLC-LH-SM will work in the interim.
5 REPLIES 5
Leo Laohoo
VIP Community Legend
SFP-GE-T
SFP-GE-S
SFP-GE-L
SFP-GE-Z
CWDM SFP
DWDM SFP
Supports the following only.  If you use anything else, TAC won't help you.
Cisco Gigabit Ethernet Transceiver Modules Compatibility Matrix
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
I have an issue in my data center, could you please me help out.
I have Cisco ASR1006 router in my data center and a 100Mpbs WAN link (over OFC) is coming from my ISP to my premises. The issue is my ISP is having 100BaseFx module at its end and I am having 1000BaseFx modules in my router. How should I terminate the OFC on my router as 100BaseFx are 1000BaseFx are incompatible ? Please recommend any SFP which I could use at my end in order to terminate the OFC directly on my router. I have an 8 port SPA on my ASR.
Leo Laohoo
ASR 1K chassis can support GLC-GE-100FX module but your 8-port SPA won't support this module (go HERE and scroll down to Table 3).
Don't forget to rate our useful posts.
thanks leo for the reply. as per the table it seems none of the SFP I can apply to my router for making it compatible with FE100FX sfp at my ISP end.
Leo Laohoo
The SFP will work if you install it on a 5- or 10-port SPA.
