Usually all the Cisco SFP are compatible with the devices, for example:
MGBBX1 is used for Multimode fiber but the SG Switches are compatible with GLC-SX-MM used for Multimode on Catalyst switches. So the Cisco 10 SFP modules should be compatible with SG and Catalyst as well.
My suggestion is contact a local Cisco partner to find the proper SFP specs. The following link could be useful as well:
https://www.cisco.com/c/dam/en/us/products/collateral/switches/small-business-500-series-stackable-managed-switches/at_a_glance_c45-726838.pdf
Usually the same SFP models are compatible with the Small Business Switches.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
