Join Customer Connection to register!
288
ivarstrandberg
Beginner
Shaping or policing video-over-http on an ASR1001
Hi.
We have a Cisco ASR1001 running 03.10.01.S (15.3(3)S1), license level advipservices.
The ASR1001 is used an internet edge router, and we'd like it to identify video streaming and make sure it doesn't exceed 1gbps of bandwidth (our connection to the internet is 2gbps).
To begin with, I have just tried to set up a performance monitor to see if I'm able to classify the data and how much bandwidth video-over-http is using at the moment.
Here is the config:
flow record type performance-monitor pmfr1
match ipv4 source address
match ipv4 destination address
match interface input
collect ipv4 protocol
collect transport source-port
collect transport destination-port
collect interface output
collect counter bytes long
collect counter packets long
collect timestamp sys-uptime first
collect timestamp sys-uptime last
flow exporter e1
destination 10.0.0.10 vrf Mgmt-intf
source GigabitEthernet0
transport udp 2055
flow monitor type performance-monitor pmm1
record pmfr1
exporter e1
class-map match-any class1
match protocol video-over-http
policy-map type performance-monitor policy1
class class1
  flow monitor pmm1
interface Port-channel1.2
encapsulation dot1Q 2
vrf forwarding INTERNET
ip address 192.168.1.2 255.255.255.252
service-policy type performance-monitor input policy1
Now...this does not work. I can't see that I'm getting any flows made...so there may be something wrong with the flow config, or maybe something wrong with the matching class or the policy.
Any ideas?
0 REPLIES 0
