Highlighted
Beginner
SHDSL Bridge - no reconnect after power loss
Hi all,
I´ve a problem with 2 Cisco 1803 Router.
This 2 Routers are connected via a 2 wire coopercable in bridgemode over SHDSL / ATM.
Actually the whole construct is up and running - fine. My problem is, that if the first router (10.122.85.20) loss his power, and come back after a few minutes, it don´t reestablish the bridge. Only after a reboot of the 2nd router, the connection come up again (may it would be enough to toggle the ATM Card, but my customer is allways in hurry)
In the manual I couldn´t find anything how i could configure this. Any ideas?
Thank you for every helpfull idea.
BR
Stephan
Here a few detail informations:
This are the configs:
10.122.85.20:
version 12.4
service password-encryption
hostname cisco20
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
dot11 syslog
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username xxx
archive
log config
  hidekeys
controller DSL 0
mode atm
line-term co
line-mode 2-wire line-zero
line-rate 1536
bridge irb
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
spanning-tree portfast
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 8/35
  encapsulation aal5snap
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.122.85.20 255.255.254.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.122.84.1
no ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
10.122.85.21:
version 12.4
hostname cisco21
boot-start-marker
boot-end-marker
enable secret 5 xxx
no aaa new-model
dot11 syslog
ip cef
username xxx
archive
log config
  hidekeys
controller DSL 0
mode atm
line-term cpe
line-rate auto
bridge irb
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface ATM0
no ip address
pvc 8/35
bridge-group 1
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 10.122.85.21 255.255.254.0
ip default-gateway 10.122.84.1
no ip http server
control-plane
bridge 1 route ip
Everyone's tags (3)
