Show controller in 7606
junaid.butt
Hello
I have installed v.35 card (PA-8T-V35) with octal cable. The problem is this that i cannot see 'show controller' information for serial ports. 'show contrller' support only this:
Router#show controllers ?
E1 E1 controller internal state
T1 T1 controller internal state
XTagATM Extended Tag ATM interface
cwan Show Catalyst WAN card related information
pos POS framer state
srp SRP controller information
| Output modifiers
<cr>
please help.
regards
-junaid
thomas.chen
Level 6
Level 6
To the best of my knowledge, I does not heard about your peoblem, I think it seems to be a hardware issue. It may be on serila ports that may not seat properly or the hardware may not work properly.
Try by restart the router, it sometime may work.
Is your router seeing the hardware?
You should see it listed if you do a show version.
johansens
Level 4
Level 4
First, do a "show diag".. you should see something like this:
Router# show diag
(display text omitted)
Slot 8: Logical_index 17
Board is analyzed ipc ready FlexWAN controller
Slot database information:
Flags: 0x2004 Insertion time: unknown
CWAN Controller Memory Size: Unknown
PA Bay 1 Information:
Mx Serial PA, 8 ports
EEPROM format version 0
HW rev 0.00, Board revision UNKNOWN
Serial number: 00000000 Part number: 00-0000-00
Here you see the PA-8T-V35 is installed ("PA Bay 1 Information: Mx Serial PA, 8 ports")
What do you get with a "show controllers cwan"?
