show ip bgp all Vs show ip bgp a.b.c.d
D@1984
when I do 'show ip bgp all' on my 8300 router, I can see all networks and the next hop, but when I choose one of those networks and do 'show ip bgp a.b.c.d/nn', the output would be %network not in table.
can someone please explain why this happens? at the moment if I need to see if I have a route for specific destination, I have to do "show ip bgp all" rather than "show ip bgp address".
I think "IPv4-unicast" is default,
but your prefix "a.b.c.d/nn" is in VPNv4 and because ALL appear all prefix for all address family then it not appear when you not use keyword ALL.
pman
"show ip bgp all"shows Information about all configured address families is displayed.
Make sure you write the IP / IP and subnet exactly as shown in "show ip bgp all"
Hi D@1984 ,
"show ip bgp all" is the legacy format for BGP. In addition to what @pman is stating, I would also recommend that you use the new format, such as "show bgp <address-family> <sub address-family>". So if you want to show the "ipv4 unicast" prefixes, you would use the following command instead of "show ip bgp all":
show bgp ipv4 unicast
and to list a specific prefix:
show bgp ipv4 unicast <a.b.c.d/nn>
Make sure you specify the right address family and sub address family.
Giuseppe Larosa
Hello D@1984 ,
as other colleagues have noted you have probably multi address famillies in your 8300 router .
show ip bgp vpnv4 all a.b.c.d/n
or
show bgp vpnv4 all a.b.c.d/n
will provide you much more details :
number of paths, best path number #
for each advertisement you will be able to see all the BGP attributes , BGP next-hop, AS Path string , MED and so on and the MP label, the RD and the set of extended communities of type route tartget rt attached to each.
show bgp /all does not provide all these details but one line per advertisement with ">" in front of best path
Hope to help
Giuseppe
