show ip interface brief command output
sivakondalarao
I have seen 'show ip interface brief' command output.
For some interfaces 'method' it is showing 'NVRAM' and for some interfaces it is 'Manual'.
What does it mean?
SKR
6 Replies 6
Joe Clarke
NVRAM means that the interface was configured via the startup configuration at boot time. Manual means the interface was configured manually after boot time.
Hi jclarke,
Thanks for your response. So, if I reload the router it shows 'Method' NVRAM right?
SKR
Yes, provided you don't do any configuration after that (and you've saved some interface config to the startup config).
Thanks jclarke.
SKR
hello,
what about CONFIG method. what is the difference between that and manual and how can I change it to CONFIG? this is related to the ASA 5585.
thanks!!
Please start a new thread for your question.  You'll likely want to ask in one of the security spaces to get the ASA experts.
