show policy-map interface with nested class-maps
LordFlasheart
I have a requirement to provide stats on a per-department, per-destination basis between sites. If I take Voice as an example I have 5 child classes referring to the 5 departments each matching EF and a particular access-list that matches the department's subnet. I tie these 5 child classes into a parent Voice class-map.
Now when I issue a "show policy-map interface" command I see stats for the parent class-map only whereas I would expect to see a breakdown for each of the child classes which is what is required.
I am doing this on an ASR1002 running 3.2.2
Anyone kn0ow what may be the issue?
Soraya Golbeg
Can you paste the output of the 'sh policy-map int <>' ?
Bear in mind that the outputs of the ASR would be different compared to other platforms.
For instance:
Service-policy input: GROUP1
    Class-map: GROUP-IN (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: access-group name GROUP-IN
      QoS Set
        dscp ef
          No packet marking statistics available  <<<
You will not be seeing hits for individual access-lists, and this is documented through the following bug:
CSCtj33068
QoS ACL counters is not supported on ASR 1000 - needs to be documented
Externally found minor (Sev4) bug: J-Junked
Symptom:
QoS ACL counters is not supported on ASR 1000 yet.
Till the time its officially supported by an IOS release, this bug will serve as a proof for customers.
Workaround:
we should rely on policy map counters only.
Hope this helps,
soraya
