show version explanation
skrao_mandalapu
Hi All,
I would like to understand below show version output.
C7609#sh ver
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICES-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 22-Feb-10 04:44 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICES-M), Version 12.2(33)SRD4, RELEASE SOFTWARE (fc2)
C7609 uptime is 17 hours, 59 minutes
Uptime for this control processor is 17 hours, 59 minutes
System returned to ROM by  power cycle at 03:21:55 IST Sun Sep 5 2010 (SP by power on)
System restarted at 20:07:07 IST Tue Jan 11 2011
System image file is "disk0:c7600s72033-advipservices-mz.122-33.SRD4.bin"
Last reload type: Normal Reload
cisco CISCO7609 (R7000) processor (revision 1.0) with 983008K/65536K bytes of memory.
Processor board ID FOX081803MQ
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
2  controllers (4 TenGigabitEthernet).
270 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Router recently rebooted at 20:07:07 IST Tue Jan 11 2011
But still why it is showing below information:
I am attaching additional information.
Siva K
Collin Clark
C7609 uptime is 17 hours, 59 minutes  --! This is how long your router has been up since last reboot.
Uptime for this control processor is 17 hours, 59 minutes   --! This is how long the contraol processer has been up
System returned to ROM by  power cycle at 03:21:55 IST Sun Sep 5 2010 (SP by power on)  --! This shows how your router was rebooted. In this case it lost power or was rebooted with the rocker switches
System restarted at 20:07:07 IST Tue Jan 11 2011   --! This is the timestamp on the router reboot
Hope it helps.
System returned to ROM by  power cycle at 03:21:55 IST Sun Sep 5 2010 (SP by power on) -------- This happened very long back.
System restarted at 20:07:07 IST Tue Jan 11 2011    --------------  This is recent event.
Why switch is still showing old reboot information, even after further reloads.
Siva K
