show version
bsudol79p
Hi I added memory to a 2611 router. When I do show version the router tells me that there is 32Megs of RAM which is incorrect. When I am in the ROMMON mode the router displays that there is 64Megs of RAM which is the correct amount. So my question is would an IOS have some restriction where it would not support more than 32Megs of RAM?
pompeychimes
Level 4
Level 4
I've never seen it in the Cisco world but most OS's do have a memory limit.
What version of code are you running? Maybe that version is so old and just dosen't recognize the additional Megs.
jiaowenbin
another command : show memory free
maybe can give some help to you
