show version
leungcm
following is the "show version" result of two AS5400. in R2 there is "276 terminal lines". does it mean that there are max 276 voice channels? Please advice
Best regards
R1
2 FastEthernet interfaces
394 Serial interfaces
384 terminal lines
16 Channelized T1/PRI ports
512K bytes of NVRAM.
65536K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
R2
276 terminal lines
16384K bytes of processor board Boot flash (Read/Write)
purohit_810
Level 5
Level 5
do show inventory command and check it..
Compare it..
Dharmesh
