Simple Project
ankitohc
Hello Experts,
Should I use the packet tracer to complete this project?  webserver should be reachable from outside interface.
pieterh
not necessarily, you need some way to determine what configuration needs to be added/modified
and prefferably check the effect of your changes
you can do this "on paper" without using packet tracer
but as packet tracer is a tool that simulates a network, you can check if the result matches what is requested
you can add devices to your network, configure the network devices with ACL's and simulate packet flow like "ping
what is issue here
please can you more elaborate
and for using PKT, no you cannot the PKT is limit
MHM
