Simple vlan ping question
hfakoor222
How do I get VPC 3 (bottom right) to ping VPC 1 (bottom left)
VPC 3 = 192.168.1.3
VPC 1 = 192.168.1.50
Switch D! Left Switch
*Jun 12 06:59:24.724: %SYS-5-CONFIG_I: Configured from console by console
D1#sh run
Building configuration...
Current configuration : 4121 bytes
! Last configuration change at 01:59:24 EST Sun Jun 12 2022
version 15.2
service compress-config
hostname D1
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5 0
ip dhcp pool THIRD_POOL
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
ip dhcp pool SECOND_POOL
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
ip dhcp pool SECOND_VLAN_POOL
ip dhcp pool THIRD_VLAN_POOL
no ip domain-lookup
ip cef
ipv6 unicast-routing
ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport mode trunk
interface GigabitEthernet0/0
media-type rj45
negotiation auto
interface GigabitEthernet0/1
media-type rj45
negotiation auto
channel-group 1 mode on
interface GigabitEthernet0/2
media-type rj45
negotiation auto
interface GigabitEthernet0/3
media-type rj45
negotiation auto
interface GigabitEthernet1/0
media-type rj45
negotiation auto
interface GigabitEthernet1/1
switchport access vlan 2
switchport mode access
media-type rj45
negotiation auto
interface GigabitEthernet1/2
media-type rj45
negotiation auto
interface Vlan1
ipv6 address FE80::D1:1 link-local
ipv6 address 2001:DB8:ACAD:1000::1/64
interface Vlan2
ip address 192.168.2.1 255.255.255.0
ipv6 address FE80::D1:2 link-local
ipv6 address 2001:DB8:ACAD:2000::1/64
interface Vlan3
ip address 192.168.3.1 255.255.255.0
ipv6 address FE80::D1:3 link-local
ipv6 address 2001:DB8:ACAD:3000::1/64
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
Switch E2 Right Switch
Switch#
*Jun 12 06:57:24.905: %SYS-5-CONFIG_I: Configured from console by consolesh run
Current configuration : 3346 bytes
! Last configuration change at 01:57:24 EST Sun Jun 12 2022
version 15.2
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
media-type rj45
negotiation auto
interface Vlan1
ip address 192.168.1.3 255.255.255.0
ipv6 address FE80::A1:1 link-local
ipv6 address 2001:DB8:ACAD:1000::3/64
no ip http server
control-plane
trunk need allow VLAN
I double check your config VLAN1 have same IP address of PC ?? I think you misocnfig here.
6 Replies 6
This wrong
You need,
L2 between two sw since both sw connect to same subnet.
You config l3 sw and that wrong
Only config trunk or access l2 between sw and you can ping
It is a trunk port between the 2
I am missing something simple to get the VPC on bottom right to send pings across the port chaannel I do not know what though
media-type rj45
negotiation auto
media-type rj45
negotiation auto
That is exactly what it was thank you
Vlan should not be a problem as you are using vlan 1.
 But, make sure the VPC can ping the gateway
And make sure you need dot1q on port channel
I did that I think it's something small I misconfigured along the way and I can't see it now it's okay though I thoght it was only me and I was going crazy...
