SIP 601 / 2 x 10 GE / throughput
    Hello Dear ,
I have SIP 601 with 2x10 GE , 10 GE for upstream and 2nd one for my backbone , my questions:
- how can i the current throughput on this sip ?
- is it working with full or half rate ?
- sip 601 is supported for 2x10GE, how can i get benifit from this feature ?
you reply is appreciated.
Ahmed
Hello Expert,
main question is , in SIP601 is there internal forwrding between SPAs ? is there need to forward through fabric ?
please update me soon ...
thanks ,,
Ahmed
thanks for reply !!!!!
here is the answer :
- Is it going to work full or half rate ? the default throughput value is 10GE, any workaround about it ?
They both can’t work at full rate at same time as below reason.
The SIP-600 [10G SIP], SIP-401 [2.5G SIP], SIP-501 [5G SIP], and SIP-601 [10G SIP] can support up to 20G of installed SPAs, but the bandwidth through the engine and the fabric is no more than 10G (SIP-600 or SIP-601). The bandwidth through the engine and the fabric is no more than 5G for the SIP-501 and is no more than 2.5G for the SIP-401.
- Is there any way that SIP601 can forward packet without going through fabric ( internal forwarding without pass through control plane ) ?
No, and forwarding traffic must go through fabric. Only control/management traffic would be handled by control plane.
- There is a possibility to upgrade IOS-XR with a specific licence to enable 20GE throughput ?
No, this is determined by HW capability.
The Cisco XR 12000 SIP-601 operates at 10 Gbps throughput by default and does not require any additional configuration or license
Hello Ahmed,
you have been kind in reporting the received feedback on this issue.
This makes this a complete story and useful for other colleagues.
Best Regards
Giuseppe
thanks Giuseppe for stopping by ...
but still i have a question //
if SIP601 is supported 2x10GE installd SPA , from this point of view ,, how much throughput will be ?
youe reply is appreciated ///
thanks
Ahmed
