SIP & RTP Ports Range
Hamidsattarrana
I have a situation where I have to VOIP Server (Vicidial Asterisk) on cloud. And locally we have client behind the Cisco Router 3825.
We have 2 Internet Connections. One for Voice another for Data.
I want to route all RTP & SIP Traffic only to VOIP to Voice ISP. How can i do that?
I am thinking about configuring an ACL and match the SIP & RTP Ports and then use Route-MAP for next hop (Voice ISP)...
I am not sure about which ports should I match with ACL?
Or is there any other way to match RTP and SIP only so that they can go via Voice ISP?
Thanks.
5 Replies 5
Joseph W. Doherty
On a router, NBAR might be able to match RTP and/or SIP.
Yes I am able to match RTP and SIP. Can you share the whole configurations?
rais
Level 7
Level 7
If all SIP/RTP has to go through VoIP Server, you can configure a static route to Server via ISP1 and a default route to ISP2.
HTH.
No we also have http traffic.
Hello Guys!
Need to route traffic on port RTP and SIP Port basis. Any idea how can I do that?
