03-23-2023
09:56 AM
- last edited on
03-24-2023
01:59 AM
by
Translator
site-to-site VPN packets are not encrypted and decrypted, please let me know what could be the problem
Site-A#sh crypto ipsec sa
interface: Ethernet0/0
Crypto map tag: cryptomap, local addr 10.10.1.1
protected vrf: (none)
local ident (addr/mask/prot/port): (10.10.1.1/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (10.10.2.2/255.255.255.255/0/0)
current_peer 10.10.2.2 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 10.10.1.1, remote crypto endpt.: 10.10.2.2
path mtu 1500, ip mtu 1500, ip mtu idb Ethernet0/0
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key cisco hostname 10.10.2.2
crypto ipsec transform-set mytransform esp-aes esp-sha-hmac
mode tunnel
crypto map cryptomap 10 ipsec-isakmp
set peer 10.10.2.2
set transform-set mytransform
match address 100
interface Ethernet0/0
ip address 10.10.1.1 255.255.255.0
interface Ethernet0/1
ip address 192.168.1.254 255.255.255.0
interface Ethernet0/2
no ip address
shutdown
interface Ethernet0/3
no ip address
shutdown
router ospf 10
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 100 permit ip host 10.10.1.1 host 10.10.2.2
encr aes
group 2
crypto isakmp key cisco hostname 10.10.1.1
mode tunnel
set peer 10.10.1.1
match address 100
ip address 10.10.2.2 255.255.255.0
ip address 172.16.1.254 255.255.255.0
no ip address
shutdown
no ip address
shutdown
router ospf 10
no ip http server
access-list 100 permit ip host 10.10.2.2 host 10.10.1.1
Solved! Go to Solution.
03-23-2023
10:13 AM
- last edited on
03-24-2023
02:01 AM
by
Translator
the access lists do not look right. Try the below:
Site-A
access-list 100 permit ip 192.168.1.0 0.0.0.255 172.16.1.0 0.0.0.255
Site-B
access-list 100 permit ip 172.16.1.0 0.0.0.255 192.168.1.0 0.0.0.255
03-23-2023
11:49 PM
- last edited on
03-24-2023
02:04 AM
by
Translator
Well, that's correct my internal host packets are not encrypted & decrypted as a defined
access-list
I configured the same as you said and my end users are not communicating with each other after that.
I found some miss configured Phse 1 i.e
I correct it --
crypto isakmp key cisco address 10.10.2.2
now it's working fine...
local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (172.16.1.0/255.255.255.0/0/0)
#pkts encaps: 4, #pkts encrypt: 4, #pkts digest: 4
#pkts decaps: 4, #pkts decrypt: 4, #pkts verify: 4
03-23-2023
10:13 AM
- last edited on
03-24-2023
02:01 AM
by
Translator
Site-A
Site-B
03-23-2023
11:49 PM
- last edited on
03-24-2023
02:04 AM
by
Translator
access-list
I correct it --
