Site-to-Site VPN
bapatsubodh
We are having a Static NAT configured on 1800 router for two hosts. Viz -a.b.c.d and p.q.r.s. for Public_Addr1, and Public_addr2. With this we are able to access these hosts from internet without any problem. Currently no firewall feature is not used, so WAN to LAN access is allowed.
Next, we plant to set up a  setup a site-to-site VPN for these two hosts with remote site hosts. Now if we configure this site-to-site VPN, then is there a possibility that our static NAT for these two hosts would not work from all the places?  This will lead us to loosing the connectivity to those hosts except from the VPN locations.
Another problem is second location can access our hosts a.b.c.d and p.q.r.s not by these private address but some totally different private address
say a1.b1.c1.d1 and p1.q1.r1.s1. So if these hosts tries to communicate with "Other side VPN"   hosts, then we need to NAT these first ( a1.b1.c1.d1, p1.q1.r1.s1 ) and then send it for encryption.
Here are the cases
Case 1. If host a.b.c.d tries to  access internet --> Then source NAT it to Public_Addr1 and then send to WAN interface of router
Case 2. If host a.b.c.d tries to access "Other side VPN" host then source NAT it with a1.b1.c1.d1 and then send the packet to Encryption Process
             Where it will be encrypted in tunnel mode and will be sent to the WAN link with other end VPN tunnel public address as destination address.
         If , [[ a.b.c.d ( Src) --and Other_Side_VPN (Dest) ] ] ----> then  NAT source address  [ [ a1.b1.c1.d1 ( Src)-- and Other_Side_VPN (Dest)] ] ---
           --------> then encrypt this packet ------> wrap it with ESP header to Other_end_VPN_Public address ---> WAN link.
         Access-list in crypto map will have source address as a1.b1.c1.d1 and target address as "other_Side_VPN hosts".
Can it be done , do we have something like nat (0) in firewall which excludes the NAT process?  But here in our case it is a two step process
Changing the soure IP to another source IP and then encrypting the packet.
Please share the experience.
Subodh
Giuseppe Larosa
Hello Subodh,
what works in this case is to configure NAT using additional route-map to check if traffic is betwern hosts and internet (to be natted) or it is between the VPN (do not NAT).
ip nat inside source static local-ip global-ip route-map ConditionalNAT
route-map ConditionaNAT
match ip address 111
access-list 111 deny ip host local-ip  remote-vpn-subnet rem-vpn-wildcardamsk
access-ist 111 permit ip host local-ip any
see
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_nat.html#wp1041067
to be noted as reported by others the route-map is available only if you are not doing port static NAT
if there were no need for static entries the ACL for NAT would be an extended ACL denying traffic between local and remote site VPN subnets.
Another point to be considered is that NAT is triggered by a packet that need to go to a NAT inside to a NAT outside interface or viceversa.
if the VPN is built using GRE over IPSec you have an addtional logical interface (the tunnel GRE ) that doesn't has a NAT configuration on it and this can help too.
Hope to help
Giuseppe
hi,
I did as per the suggestion but I ran into following problems.
location A source IP address : 10.10.1.1
The address to which 10.10.1.1 needs to be source NATed  while accessing Loaction B is 172.16.1.1
Location B address : 10.10.2.1 .
That means when 10.10.1.1 pings to 10.10.2.1 ( location B),  source address 10.10.1.1 needs to be changed to 172.16.1.1
so packet becomes [ ( src: 172.16.1.) , (Dest - 10.10.2.1) ]  this packet is then encrypted
crypto map access-list is permit icmp / ip  from host 172.16.1.1  to destination host 10.10.2.1
I have defined following access lists and nat translations
CASE : 1 :
access-list 101 permit icmp host 10.10.1.2 host 10.10.1.1
access-list 101 permit ip host 10.10.1.2 host 10.10.1.1
ip nat pool
ip nat pool ca 172.16.1.1 172.16.1.1 prefix-length 24 ( this is a single host )
ip nat inside source list 101 pool ca ( overload and reversible )
when I used this configuration , I was able to ping from location A to location B
that is ping 10.10.2.1 source 10.10.1.1 was working ok. But from location B if I ping 172.16.1.1 sou 10.10.2.1 it gave me UUUUU responce.
I configured overoload as well as reversible but still UUUUU and not !!!!!.
CASE 2:
Then I replaced nat by route map
route-map abcd permit 10
mat ip addres 101
and then i used it for nat statement with route map as follows
ip nat inside source  static 10.10.1.1  172.16.1.1 route-map abcd
With this I got ping responce from both the locations.
Location A : ping 10.10.2.1 sou 10.10.1.1 working ok
Location B : ping 172.16.1.1 sou     10.10.2.1 working ok
Can I know what is wrong with CASE 1: nat configuration with list and how is it working CASE 2: with route-map ?
Subodh
Hello Subdoh,
the scenario is more complex for the presence of the crypto map.
However, I think the difference is that in second case using the static keyword you allow translations that starts from outside to inside:
The following example shows how to configure route map R1 to allow outside-to-inside translation for static NAT:
ip nat inside source static 10.1.1.1 10.2.2.2 route-map R1 reversible
ip access-list extended ACL-A
 permit ip any 10.1.10.128 0.0.0.127
route-map R1 permit 10
 match ip address ACL-A
! this is in the usage guidelines of NAT command reference
In your first configuration you use a NAT pool and not the static keyword.
To see if this is true you could try to use the route-map without the static keyword combined with the NAT pool.
I would expect that there are still problems when starting the ICMP from other side.
Hope to help
Giuseppe
