Sizing vPC Peer Link
ecornwell
Level 2
Level 2
I'm looking at setting up a set of 3524x's in a vPC domain.  I've seen a lot of recommendations and they usually involve a pair of 10G links.  From what I've read/understand, there shouldn't be a lot of traffic on these links during normal operation.  Is there any kind of sizing recommendations?
Thanks!
2 Accepted Solutions
Francesco Molino
You're right there shouldn't be a lot of unicast traffic unless vpc member ports go down on 1 member.
It's also used to replicate multicast steam and do all sync between the 2 boxes.
In terms of recommendation, vpc peer link won't work on 1G links and Cisco says that you must have 2 x 10G links.
Here 1 of multiple documentation available as vpc best practices:
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Joseph W. Doherty
Normally, you shouldn't see any significant traffic on that link, except in case of other hardware failure that makes the peer link the backup/alternative path. As such, if you look at your hardware, and consider worst case for traffic that might be shifted, you could size your peer link capacity accordingly.
5 Replies 5
Francesco Molino
Francesco
Joseph W. Doherty
ecornwell
Level 2
Level 2
Thank you both for your replies!
Looks like I shouldn't need to go larger than 2x10G connections.
Thanks!
You're welcome
Francesco
Probably not, but, again, you need to consider possible hardware failures. For example, might a whole line card failure push you above 20G?
