Slow 10Gb link
nelsonk
I have a 10Gb link between two sites about a 1k miles apart.  I have a Cat 6506 on one end and a Nex 7018 on the other. I have a laptop plugged in to each side.  I run iperf tests with various settings changing the window sizes and find that it really doesn’t make a huge difference to the outcome of the tests.
To get a baseline I plugged another laptop in to a different port on the switches IE: PC1 = 3/4 , PC2= 2/7 and run iperf and get the following results- 6506 = 550 Mb average, 7018 = 939 Mb average.
When I try a iperf test across the 10Gb link I get 17-18Mb. If I change the test and run it with 10 parallel threads I only get 17-18 Mb per thread but can get 700-800 Mb total bandwidth. My limiting factor is my hosts are connected via 1Gb links I will not get 10 Gb.
I am trying to figure out why I am only getting 17-18 Mb per thread across this 10 Gb link.
Thanks for any ideas anyone can provide,
7 Replies 7
vmiller
Level 7
Level 7
Unless there are some layer 2 errors showing up on the link, Its doubtful that its the 10G.
http://cisconet.com/traffic-analysis/throughput/104-tcp-throughput-calculation-formula.html
Most times its TCP setup on the end stations that make things appear slow.
Leo Laohoo
Stupid question:  Dark fibre or via an ISP?
Can you post the output to the command "sh interface ten X/Y/Z"?
Thanks for the reply.
ISP
Ethernet5/8 is up
Dedicated Interface
  Hardware: 10000 Ethernet, address: 44b3.dc84.b22f (bia 44b3.dc84.b22f)
  Description: 10Gb link
  MTU 9216 bytes, BW 10000000 Kbit, DLY 10 usec
  reliability 255/255, txload 1/255, rxload 3/255
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 1week(s) 6day(s)
  23 interface resets
  30 seconds input rate 167858264 bits/sec, 17340 packets/sec
  30 seconds output rate 7295136 bits/sec, 4024 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 134.38 Mbps, 14.29 Kpps; output rate 5.54 Mbps, 3.16 Kpps
  RX
    77214448366 unicast packets  217239922 multicast packets  247003260 broadcast packets
    77678699778 input packets  86652678395790 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  1 CRC  0 no buffer
    2 input error  1 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    20043125899 unicast packets  301631055 multicast packets  470815729 broadcast packets
    20815572683 output packets  11397424890924 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
Hmm. non zero counters for resets, input erros and crc.
I'd clear the counters at a specic time, then check 24 hours later.
Since the last clearing of show interfaces was "never" we don't know when those errors occured.
Here they are 29 hours later.
Ethernet5/8 is up
Dedicated Interface
  Description: DMSP Beltline link
  reliability 255/255, txload 1/255, rxload 2/255
  Encapsulation ARPA
  Port mode is trunk
  EtherType is 0x8100
  Last link flapped 13:49:05
  Last clearing of "show interface" counters 1d05h
  1 interface resets
  30 seconds input rate 105473208 bits/sec, 12087 packets/sec
  30 seconds output rate 4216576 bits/sec, 3273 packets/sec
    input rate 107.97 Mbps, 12.34 Kpps; output rate 7.11 Mbps, 3.72 Kpps
  RX
    1060231327 unicast packets  2602443 multicast packets  2611436 broadcast packets
    1065445205 input packets  1090897061568 bytes
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 Rx pause
  TX
    343355770 unicast packets  1503259 multicast packets  771391 broadcast packets
    345630420 output packets  198922907428 bytes
    0 jumbo packets
    0 Tx pause
Sorry, you got a 10 Gbps link from an ISP????
You sure about that???
vmiller
Level 7
Level 7
no low level link issues. I'd look to workstation tuning.
