03-07-2014 06:29 AM - edited 03-04-2019 10:31 PM
in our branch office. we are using cisco 2621 as edge router connected to 10M uplink leased line. and for users using 3560.
users always complaing about slow speed while there is no error anywher in the interface.except some drops in input queue.
03-07-2014 12:27 PM
FastEthernet0/0 is up, line protocol is up
Internet address is x/30
Broadcast address is 255.255.255.255
Address determined by non-volatile memory
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is INBOUND
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP CEF Feature Fast switching turbo vector
IP multicast fast switching is disabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is enabled, interface in domain outside
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
FastEthernet0/1 is up, line protocol is up
Internet address is x/24
MTU is 1500 bytes
Inbound access list is not set
Network address translation is enabled, interface in domain inside
BGP Policy Mapping is disabled FastEthernet0/1 is up, line protocol is up
MTU is 1500 bytes
03-07-2014 12:33 PM
any suggestion for replacement device of this old 2600 ?
03-07-2014 12:41 PM
Robab,
I would like at the ISR G2 1900 series if I were you.
03-07-2014 12:57 PM
What happens if you do the following.
no ip route-cache
ip cef
If it were me, and you can get away with it, I would upgrade the IOS.
Also setting the 'load-interval to 30' and checking on 'show processes cpu' from time to time might be wise, to see if a micro burst is happening.
