SM-X-ES3-16-P= doesn't work with ISR4331-DC/K9
luca.bartolone
Hi Team, This is a question from a customer
"We have problems with SM-X-ES3-16-P= on router ISR4331-DC/K9.
The SM-X-ES3-16-P= the card attempts to boot but fails.
The IOS of the SM-X-ES3-16-P= is Version 15.0(2r)EJ and the ios of ISR is Version 16.9.1.
can you tell me if there is a compatibility problem with the releases?"
For that first recommended as per this forum discussion that -https://community.cisco.com/t5/switching/sm-x-es3-16-p-out-of-service/td-p/4483893
SM-X-ES3-16-P is only supported on the 4451-X.
But customer mentioned that they have another ISR 4331 with installated and worked the module SM-X-ES3-16-P=
Request for comments. Is their any version specific as mentioned in this discussion fourm
https://community.cisco.com/t5/routing/isr4331-with-quot-sm-x-16g4m2x-quot-module/td-p/4432280
ISR4331 with module that WORKING
------------------ show inventory ------------------
INFO: Please use "show license UDI" to get serial number for licensing.
NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331-DC/K9 , VID: V03 , SN: FDO2437M1RY
NAME: "Power Supply Module 0", DESCR: "Unknown Power Supply"
PID: PWR-4330-DC , VID: V02 , SN: DCC2432K0E7
NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly"
PID: ACS-4330-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331-DC/K9 , VID: , SN:
NAME: "NIM subslot 0/1", DESCR: "16 ports Async Serial NIM"
PID: NIM-16A , VID: V03 , SN: DNI24200AZG
NAME: "NIM subslot 0/0", DESCR: "Front Panel 3 ports Gigabitethernet Module"
PID: ISR4331-3x1GE , VID: V01 , SN:
NAME: "subslot 0/0 transceiver 0", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V02 , SN: ACW24271PB3
NAME: "module 1", DESCR: "Cisco ISR4331 Built-In SM controller"
NAME: "SM subslot 1/0", DESCR: "SM-X-ES3-16-P: EtherSwitch SM L3 + PoEPlus + MACSec + 16 10/100/1000"
PID: SM-X-ES3-16-P , VID: V01 , SN: FOC242949NM
NAME: "module R0", DESCR: "Cisco ISR4331 Route Processor"
PID: ISR4331-DC/K9 , VID: V03 , SN: FDO24350AC3
NAME: "module F0", DESCR: "Cisco ISR4331 Forwarding Processor"
Thanks and Regards,
0 Replies 0
