Smart licensing error in Cisco 1121 router
Rajesh11735
Hello Guys,
I had installed security license for Cisco 1100 ISR few months ago and now I am getting the below error. I have posted my running configuration and few more outputs. Any help would be much appreciated.
Failure reason: Fail to send out Call Home HTTP message. (or)
Failure reason: SACL http unknown host
sh version (truncated o/p)
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 None Smart License None
securityk9 securityk9 Smart License securityk9
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: REGISTERED/AUTH EXPIRED
Router#show call-home profile all
Profile Name: CiscoTAC-1
Profile status: ACTIVE
Profile mode: Full Reporting
Reporting Data: Smart Call Home, Smart Licensing
Preferred Message Format: xml
Message Size Limit: 3145728 Bytes
Transport Method: http
HTTP address: https://tools.cisco.com/its/service/oddce/services/DDCEService
Other address(es): default
Periodic configuration info message is scheduled every 15 day of the month at 15:41
Periodic inventory info message is scheduled every 15 day of the month at 15:26
Alert-group Severity
crash debugging
environment minor
inventory normal
Syslog-Pattern Severity
.* major
Router#telnet tools.cisco.com 443 /source-interface gigabitEthernet 0/0/0
% Bad IP address or host name
Router#telnet 173.37.145.8 443 /source-interface gigabitEthernet 0/0/0
Trying 173.37.145.8, 443 ... Open
^C
[Connection to 173.37.145.8 closed by foreign host]
Router##show run all | in destination address http
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
Router#show lice all
Smart Licensing is ENABLED
Registration:
Status: REGISTERED
Smart Account: XXXXXXX
Virtual Account: AccXXX
Export-Controlled Functionality: ALLOWED
Initial Registration: SUCCEEDED on Nov 04 09:30:59 2022 summer
Last Renewal Attempt: FAILED on Jun 29 15:18:45 2023 summer
Next Renewal Attempt: Jun 29 15:19:14 2023 summer
Registration Expires: Nov 04 09:22:36 2023 summer
License Authorization:
Status: AUTH EXPIRED on Jun 29 15:18:54 2023 summer
Last Communication Attempt: FAILED on Jun 29 15:18:54 2023 summer
Next Communication Attempt: Jun 29 16:18:44 2023 summer
Communication Deadline: DEADLINE EXCEEDED
License Conversion:
Automatic Conversion Enabled: False
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Smart
URL: https://smartreceiver.cisco.com/licservice/license
Proxy:
Not Supported
Miscellaneus:
Custom Id: <empty>
License Usage
(ISR_1100_4P_Security):
Description:
Count: 1
Version: 1.0
Export status: NOT RESTRICTED
Product Information
UDI: PID:C1121-4P,SN:XXXXXX
Agent Version
Smart Agent for Licensing: 4.11.5_rel/41
Reservation Info
License reservation: DISABLED
Router#ping 171.70.168.183
Sending 5, 100-byte ICMP Echos to 171.70.168.183, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#ping tools.cisco.com
% Unrecognized host or address, or protocol not running.
Router#ping 173.37.145.8
Sending 5, 100-byte ICMP Echos to 173.37.145.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/52/64 ms
Running config
ip name-server 8.8.8.8
no ip domain lookup
ip domain name custvpn
crypto pki trustpoint TP-self-signed-141864XX
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-141864XX
revocation-check none
rsakeypair TP-self-signed-1418643960
crypto pki trustpoint SLA-TrustPoint
enrollment terminal
license udi pid C1121-4P sn XXXXXXXX
license boot level securityk9
license smart url default
license smart transport smart
ip http server
ip http secure-server
ip http secure-trustpoint SLA-TrustPoint
ip http client source-interface GigabitEthernet0/0/0
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
Best Regards,
Rajesh
17 Replies 17
 It seesm you hit a bug. Try to change the ios version
Cisco Bug: CSCvv72609
SmartLicense: High CPU usage triggered by RUM reports
Last Modified
Jul 01, 2023
Products (22)
Cisco 1000 Series Integrated Services Routers, Cisco 4000 Series Integrated Services Routers, Cisco 8000 Series Routers, Cisco 9800 Series Wireless Controllers, Cisco ASR 1000 Series Aggregation Services Routers, Cisco Catalyst 8000V Edge Software, Cisco Catalyst 8200 Series Edge Platforms, Cisco Catalyst 8200 Series Edge uCPE, Cisco Catalyst 8300 Series Edge Platforms, Cisco Catalyst 8300 Series Edge Universal CPE
Known Affected Release
17.3
Thanks again, Flavio. I stumbled over the bug related article earlier today. Hopefully, that will solve the issue.
Grateful for all your quick responses and help throughout this post.
You're welcome. Hopefullyit fix the problem.
