06-23-2005 01:31 PM - edited 03-03-2019 09:53 AM
SMTP protocol problem with CISCO 836
Hi all,
I am not sure what I have to change in my CISCO 836 configuration in order my server will not deny incoming email ... I can send emails outside our network no-problem however if I want to send something in I am getting mail bounced back with message as follows:
Technical details of permanent failure:
PERM_FAILURE: SMTP Error (state 10): 550 Invalid recipient:
I checked Microsoft site since we are using Windows 2003 server with Exchange and they posted there it is a CISCO problem...they are saying DISABLE SMTP protection on firewall, however I don't know if it is good to disable TCP inspection, since I still need that however I would like to permit SMTP protocol.
Bellow is my access list with Dialer configuration. My question is what should I change there? Is it the problem in
access list or is it problem in tcp inspection and what should be changed? Other then that I don't find any problem with my router configuration!
access-list 111 remark Outside (Internet) firewall
access-list 111 deny icmp any any echo
access-list 111 permit icmp any any administratively-prohibited
access-list 111 permit icmp any any echo-reply
access-list 111 permit icmp any any packet-too-big
access-list 111 permit icmp any any time-exceeded
access-list 111 permit icmp any any unreachable
access-list 111 permit udp any eq bootps any eq bootpc
access-list 111 permit udp any eq bootps any eq bootps
access-list 111 permit udp any eq domain any
access-list 111 permit esp any any
access-list 111 permit udp any any eq isakmp
access-list 111 permit udp any any eq 10000
access-list 111 permit tcp any any eq 1723
access-list 111 permit tcp any any eq 139
access-list 111 permit udp any any eq netbios-ns
access-list 111 permit udp any any eq netbios-dgm
access-list 111 permit gre any any
access-list 111 permit tcp any any eq www
access-list 111 deny ip any any log
ip inspect name PUBLIC_ACCESS tcp
interface Dialer1
ip address negotiated
ip access-group 111 in
ip nat outside
ip inspect myfw out
ip inspect PUBLIC_ACCESS in
encapsulation ppp ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 0
ppp pap sent-username password 0
Need help ASAP.
Rgds,
csakos
06-29-2005 10:35 AM
Are you sure of that email address and do you have a account or anything that can be tried. Can you double check the information in mail client accounts to make sure the email address is correct for the account that you are sending from.
07-20-2005 01:10 AM
Well I figured out what was the problem. In my configuration I was blocking port 25 so I added additonal line in my configuration and now SMTP works fine.
ip nat inside source static tcp 192.168.1.5 25 interface Dialer1 25
csakos
