11-09-2006 07:23 AM - edited 03-03-2019 02:39 PM
Hello dear all,
I have some unwanted traffic on my switch port.
how can I findout IP addresses of the generator of these trafics?
thanks
11-09-2006 07:54 AM
Hi Friend,
Which switch you are having on which you want to sniff the ports. You can configure SPAN on your switch and sniff the ports which ever you want.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12225see/scg/swspan.htm#wp1036816
EtherReal sniffer software will be one good option which you can have on your destination machine to capture traffic.
Ankur
*Pls rate all helpfull post
11-09-2006 10:44 AM
ps... etherreal is now wireshark
11-09-2006 07:56 AM
Hi ,
You can span your switchport traffic to another port and connect a pc with a sniffer or ethereal software to find the traffic
Hope this helps
regards
vanesh k
11-09-2006 09:58 AM
You can use the poor mans sniffer.. If your traffic goes through a layer 3 interface then you can enable route cache flow on the interface. capture the traffic, then do a show cache flow. it will show you the ip addresses source/destinations flows through the interface and ports they are using..
