snmp traps
thomasandy32
Hello Experts,
I have enabled all snmp traps on 6500 switch,i want to know the description of each trap and severty level for each trap,where can i find it???
can anybody route me to the proper document.
snmp-server system-shutdown
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps chassis
snmp-server enable traps module
snmp-server enable traps transceiver all
snmp-server enable traps ds1
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps casa
snmp-server enable traps tty
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps config-copy
snmp-server enable traps event-manager
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps l2tc threshold
snmp-server enable traps MAC-Notification change move threshold
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps rf
snmp-server enable traps rtr
snmp-server enable traps slb real virtual csrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps mvpn
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls fast-reroute protected
snmp-server enable traps mpls ldp
snmp-server enable traps pw vc
snmp-server enable traps memory bufferpeak
snmp-server enable traps flex-links status
snmp-server enable traps sonet
snmp-server enable traps dial
snmp-server enable traps fru-ctrl ps-output-change status
snmp-server enable traps entity
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps power-ethernet group 1-48
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps csg agent quota-server database
snmp-server enable traps srp
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps c6kxbar intbus-crcexcd intbus-crcrcvrd swbus
snmp-server enable traps dot1x no-guest-vlan no-auth-fail-vlan
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps port-security
snmp-server enable traps vswitch vsl
snmp-server enable traps alarms
snmp-server enable traps vlan-mac-limit
snmp-server enable traps mpls vpn
snmp-server enable traps voice poor-qov
6 Replies 6
Reza Sharifi
Are you looking for this command?
The severty  is after alarms
Switch(config)#snmp-server enable traps ala
Switch(config)#snmp-server enable traps alarms ?
  <1-4>          Max Severity of the Alarm Notifications
  critical       Service affecting Condition       (severity=1)
  informational  Informational notifications       (severity=4)
  major          Immediate action needed           (severity=2)
  minor          Minor warning conditions          (severity=3)
Reza
Hello Sharifi,
I m looking for the severity level of each traps that i have enabled. For Example: suppose if switch module goes faulty then snmp-server enable traps module trap will be triggered , so this trap will be in which severity ???
Feb 16 16:37:02.499: %C6KPWR-SP-2-PSFAIL: power supply 2 output failed.
Feb 16 16:37:02.503: %SNMP-5-CHASSISALARM: Chassis Alarm Trap: tmpAlarm(OFF), minorAlarm(ON), and/or majorAlarm(OFF)
I'm receiving snmp traps in syslogs how i can see only snmp traps apart from the syslogs.what is the command to chk snmp traps on the 6500 switch??.
Hello friends,
Can anybody helpme for the above query.
Hello Dears
Nobody from cisco experts can answer my above question????  Answer will be highly appreciable.
my understanding is:
Each of the commands
"snmp-server enable traps xxxx"
enables one family (Cisco calls it type) of traps being sent.
snmp-server enable traps stp - enables STP traps, e.g., all severities.
I'm not sure if it's possible to configure severity of particular traps with IOS, though.
I remember this was possible in CatOS in the past.
Traps are sent to SNMP port (UDP 162 if I remember correctly). You need a SNMP trap receiver program (like HP OV NNM, e.g.) to handle the traps received then.
"snmp-server enable traps syslog" makes the switch to sent a copy of each trap to your Syslog, too.
HTH,
Milan
I have to correct what snmp-server enable traps syslog actually does.  It sends what ever is sent to syslog as an snmp OID to what you have recieving your traps.  I wouldn't turn this on if you have a huge network or you will be bombarded with a tone of syslog messages.
