SNT
Ibrahim Jamil
Level 6
Level 6
does the SNT-SMARTnet 8x5xNBD (8X5XNBD) ,allows me to open TAC Case for configuration and Design ? i have an ISP Project
thanks
Jamil
5 Replies 5
aguante_boca
As I believe, each product from Cisco could be used for opening a TAC ticket.
Can i open for TAC for Design and Configuration???????
Configuration questions, should be no problem. Design, not so much. Thats usually aprofessional services engagement
Smartnet is essentially break/fix/upgrade and very specific tech issues.
Never hurts to try......
Hi vmiller
thanks for ur reply
ibrahim
There is a forum for design questions under the infrastructure heading (above) You could pose your issues there & see what comes out of it, it does have the advantage of being free.
https://supportforums.cisco.com/community/netpro/network-infrastructure/design-architecture
