Some doubts about Rv320 router
Juan L. Olmos
First of all, sorry if posting in wrong forum...
We have a customer that needs a router with the following characteristics for a branch office:
- 2 Gigabit Ethernet WAN ports
- Support of route mapping (route-map and ip policy route-map commands)
I can't see in the manual or in the datasheet if the RV320 Router permits to run route-mapping commands. It seems that the router only has web management.
Could anybody confirm me if the RV320 Router permits route mapping configuration?
Thanks in advance
Juan L.
Mark Malone
Hi Juan
you mean like policy based routing ? , the lowest that will do that is an 800 series , I have never seen PBR on an SMB router , also you will need a license to support PBR its advanced feature set requires ipservcies for it to work correctly , with that though you will get everything else like BGP and all IGP protocols etc
EDIT: you can check yourself all the emulators are available online to be sure :)
https://supportforums.cisco.com/group/911/cisco-small-business-online-device-emulators
Mark Malone
Hi Juan
