some websites work others dont 1841 router
chomiczmichael
hello!
just configured a 1841 router and im trying to figure out why some websites work and others dont - when i put in a small TP-LINK everything works fine so its not my ISP - any suggestions?
my config:
Building configuration...
Current configuration : 3057 bytes
version 12.4
hostname RT1841
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$nRsK$6JevOfdqAjpN5Ak/190jF1
no aaa new-model
ip source-route
ip dhcp database DHCP_POOL
ip dhcp excluded-address 10.0.0.1
ip dhcp pool DHCP_POOL
   network 10.0.0.0 255.255.255.128
   domain-name chomiczki.com
   dns-server 10.0.0.1
   default-router 10.0.0.1
   lease 7
ip cef
no ipv6 cef
vpdn enable
vpdn-group home
request-dialin
  protocol pppoe
spanning-tree vlan 666 priority 0
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
description ADSL WAN interface PPOE
mtu 1410
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/0/0
switchport access vlan 666
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
interface Vlan666
ip address 10.0.0.1 255.255.255.128
ip nat inside
interface Dialer1
description Wan Dialer
mtu 1492
ip address negotiated
no ip unreachables
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxxxxx
ppp chap password 0 xxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxxxxxx password 0 xxxxxxxxxxxx
ppp ipcp dns request
ppp ipcp route default
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 10 interface Dialer1 overload
access-list 10 permit 10.0.0.0 0.0.0.255
no cdp run
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxxxxxxxxxx
login
scheduler allocate 20000 1000
end
hi Michael,
chomiczmichael wrote:
thanks for the suggestion - i've made the changes - even set the ip mtu to 1410 but still no good
I am not sure where you are getting the 1410 figure from? Did you remove it from the fa0/1 though? ok can u please set the  ip mtu  on the dialer interface to 1492 and also on the fa0/0 put in   "ip tcp adjust-mss 1452" .
Also, on that TP LINK modem router you were using, did you check what mtu is that set to?
6 Replies 6
sean_evershed
Level 7
Level 7
What sort of error message do you get?
As a test can you try changing your DNS to point to one of the publicly available DNS servers like Google? See below:
http://code.google.com/speed/public-dns/
hi sean
the pages take extremely long to load - didnt wait long enough to give an error - i've already tried the google dns servers too.. but like i said - i throw in a small TP-LINK router in and same pages go quick
hi Michael,
I believe this is to do wit MTU settings on your router. I have made some suggestions. can u please try and see if it works?
after the below changes if it still doesnt work then please try to lower the mtu value on the dialer interface to a lower value till you are able to get to all the websites.
duplex auto
speed auto
mtu 1410                                                  <<<
no ip address
interface Dialer1
mtu 1492                                        <<
no ip unreachables
ip nat outside
HTH,
Please rate if helpful
hi Michael,
hi kishore
the f0/1 isnt connected to anything - i have a 4 port hwic card installed on the router - i have added the ip tcp adj 1452 on the vlan interface and everything is working fine now
thanks for your help
