10-06-2005 01:16 PM - edited 03-03-2019 10:40 AM
Is it possible to do source based routing on a 3750 switch? This is my core vlan routing device.
Here is the situation. I have a vlan which I want all traffic (including internet) to default to 3725 router, to be shuttled out it's serial port, rather then sent to the default route.
I know this is done through policy based routing, as I have done it before on the 3725. However, after creating the route-map, when I go into the vlan interface I cannot run the command "ip policy route-map <name>". It stops at policy, saying it's an undefined command.
Does anyone have any idea on how to do this on a a layer 3 switch, or can it not be done?
Thanks!
10-06-2005 03:04 PM
I'm pretty sure PBR is supported on 3750's. It may require enhanced image though. Do a show version and see if you are running standard or enhanced image.
Daniel
10-06-2005 03:09 PM
Actually, I just looked at the latest configuration guide and it says you need to enable PBR.
In global configuration mode -
sdm prefer routing
Daniel
