Source based routing
kjanakiraman
I have two subnets, by default all traffic goes through path 1. For one destination say x.x.x.x, subnet one should take path 1 and subnet two should take path 2. How can i achieve this.
Thanks in Advance
6 Replies 6
ankurbhasin
Level 9
Level 9
Hi Friend,
Yes that is possible through Policy Base Routing (PBR)
Try this config and I think this should work
route-map Test permit 10
match ip address 100
set ip next-hop <-----Path 1
route-map Test permit 20
match ip address 200
set ip next-hop <-----Path 2
access-list 100 permit ip
access-list 200 permit ip
Router(config)interface fa0/1
Router(config-if)# ip policy route-map Test
You can define your first subnet as source network A in ACL 100 and second subnet as source network B in ACL 200.
HTH, if yes please rate the post.
Ankur
Only as a reminder, dont forget that Policy Based Routing could be sometimes called a static routing based on source.
So you have to be carefull not losing the reliability of your routing.
there are some routing features to help you.
-Policy Based Routing: Recursive Next Hop
-PBR Support for Multiple Tracking Options
But those are only available in some plataforms and some IOS versions.
HTH,
if it does, please rate this post, I'd appreciate.
Vlad
amit-singh
Level 8
Level 8
Please also check the current CPU utilization, and memory on teh router as well. The PBR is a CPU intensive feature and once you enable it it will take a large number of CPU cycles to make the decisions. Check the memory part also, you should have adequate memory on the router to support it.
HTH, Please rate if it does.
-amit singh
scottmac
Level 10
Level 10
Just use a static route.
IP ROUTE xxx.xxx.xxx.xxx mm.mm.mm.mm yy.yy.yy.yy
xx=the net/subnet you want to direct yy=the address of the next hop for the path mm=network mask
Use the Default Gateway / GW of Last Resort for the main traffic, and a static for the exception traffic.
Easy to do and not so hard on the resources.
Good Luck
Scott
Hello Scott,
I'm not sure static routes will help him in this case as he is doing source based routing.
As I understood, he needs to sent traffic from subnet1 to 1 path and from subnet 2 to 2 path , when going to the same destination.
So, I believe Policy Based Routing will be the solution. Enabling CEF helps on the CPU issues.
Vlad
Hi Scott,
Static routes is a detination base routing method which cannot be used to take the decision based on source subnet. So as updated in my first post and also by Vlad, PBR will be the simplest way to achieve original poster requirement.
Ankur
