Join Customer Connection to register!
1291
Highlighted
Beginner
%SPA_OIR-3-UNSUPPORTED 7609-S SIP-400
We installed a SPA 4XT3/E3 Copper DS3 Module into our Cisco 7609 SIP-400 Module and got these errors:
SPA-INSCARD: Card inserted in Subslot 2
SPA-UNSUPPORTED: The SPA-4XT3/E3 in 4/2 is unsupported by the SIP-400
SPA-INSCARD: Card inserted in Subslot 3
SPA-UNSUPPORTED: The SPA-4XT3/E3 in 4/3 is unsupported by the SIP-400
Module        Model                Operational Status
subslot 4/2   SPA-4XT3/E3          out of service(not allowed online)
subslot 4/3   SPA-4XT3/E3          out of service(not allowed online)
                          H/W   Field Programmable  Current  Minimum
Slot Card Type             Ver.  Device: "ID-Name"   Version  Version
4/2 SPA-4XT3/E3 <DISABLED> 0.655 ????????????        ?.?      ?.?
4/3 SPA-4XT3/E3 <DISABLED> 0.655 ????????????        ?.?      ?.?
We reloaded the SPA and SIP cards with no luck.
A text document of the sh log, sh module, and show monitor event-trace spa latest are attached.
2 ACCEPTED SOLUTIONS
Highlighted
Hall of Fame Master
Hello Dennis,
it should be supported as reported here
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76intsw.html#wp1144362
table 2-5
from your log files I see you are running 12.2(33)SRB2 I would suggest if possible to test with another IOS image like SRE series
Hope to help
Giuseppe
Highlighted
This spa is not supported in the sip-400 until SRC.
http://www.cisco.com/en/US/docs/routers/7600/Hardware/12.2SR_supported_hw/7600_hwd.html#wp1036097
You will need to run SRC or higher for this combination to work
David Aicher
3 REPLIES 3
Highlighted
Hall of Fame Master
Hello Dennis,
table 2-5
Hope to help
Giuseppe
Highlighted
David Aicher
Highlighted
Beginner
Thanks guys!
We actually were talking to our Cisco sales rep and was told that this was compatible, until we inserted it into the SIP module. The logs definately tell the story. We are looking at upgrading our IOS after we confirm and close this ticket with TAC.
I'm glad I posted here. Very helpful!!!
