05-10-2006 02:37 AM - edited 03-03-2019 12:38 PM
I tried config span on my 6509 switch, but somehow not actived after i configured, please check the configuration and the log:
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 100 name vlan100 type ethernet mtu 1500 said 100100 state active
set vlan 200 name vlan200 type ethernet mtu 1500 said 100200 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active stp ibm
set vlan 10
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state active mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sl0 down
set interface sc1 down
set ip alias default 0.0.0.0
#ntp
set timezone GMT 8 0
#set boot command
set boot config-register 0x2102
set boot system flash bootflash:cat6000-sup2k8.7-6-7.bin
#port channel
set port channel 2/15-16 127
# default port status is enable
#module 1 : 2-port 1000BaseX Supervisor
set trunk 1/2 on isl 1-1005,1025-4094
#module 2 : 16-port 1000BaseX Ethernet
set port disable 2/2-10
set udld enable 2/7-10
set trunk 2/15 on dot1q 1-1005,1025-4094
set trunk 2/16 on dot1q 1-1005,1025-4094
set port channel 2/15-16 mode desirable non-silent
#module 3 empty
#module 4 empty
#module 5 empty
#module 6 empty
#module 7 empty
#module 8 empty
#module 9 : 48-port 10/100/1000BaseT Ethernet
set vlan 100 9/1,9/9-13
set vlan 200 9/4,9/47-48
set port disable 9/6-8,9/10,9/14-48
set port speed 9/1-3,9/11-14,9/47-48 100
set port speed 9/9 1000
set port duplex 9/1-3,9/11-14,9/47-48 full
set port name 9/1 outside
set port name 9/2 mangement
set port name 9/3 SGP1001
set port name 9/12 Packeteer
set port name 9/13 Span Port - NetQoS
set port flowcontrol 9/13 receive on
#module 15 : 1-port Multilayer Switch Feature Card
#module 16 empty
#switch port analyzer
set span 9/1 2/1 both inpkts disable learning enable multicast enable create
end
CORESW> (enable) sh span
Destination : Port 2/1
Admin Source : Port 9/1
Oper Source : None
Direction : transmit/receive
Incoming Packets: disabled
Learning : enabled
Multicast : enabled
Filter : -
Status : inactive
Total local span sessions: 1
how to make it active?
05-10-2006 05:34 AM
Hi Friend,
Make sure you have your source and destination port connected. Also Change the command
"set span 9/1 2/1 both inpkts disable learning enable multicast enable create " to
set span 9/1 2/1 both inpkts disable learning enable multicast enable and press enter.
This should make it work.
HTH, Please rate if it does.
-amit singh
05-10-2006 08:11 AM
I think that Amit is on the right track when he comments about the source and destination ports. It would be helpful to see the output of show port 2/1 and show port 9/1. I suspect that one (or perhaps both) of the ports is not active.
Rick
