05-31-2016 11:40 AM - edited 03-05-2019 04:07 AM
When looking at the spanning-tree summary page, what does it mean when counters increment under the "Forwarding and STP active" column?
For example for VLAN0005 and 0006, I saw that the counters increment by 1 over the weekend. What does this tell me?
show spann tree summary
Switch is in pvst mode
Root bridge for: none
EtherChannel misconfig guard is enabled
Extended system ID is enabled
Portfast Default is disabled
PortFast BPDU Guard Default is enabled
Portfast BPDU Filter Default is disabled
Loopguard Default is enabled
UplinkFast is disabled
BackboneFast is disabled
Configured Pathcost method used is short
Name Blocking Listening Learning Forwarding STP Active
VLAN0001 0 0 0 1 1
VLAN0002 0 0 0 2 2
VLAN0003 0 0 0 1 1
VLAN0004 0 0 0 10 10
VLAN0005 0 0 0 4 4
VLAN0006 0 0 0 9 9
VLAN0007 0 0 0 14 14
7 vlans 0 0 0 41 41
Solved! Go to Solution.
05-31-2016 11:46 PM
it should be number of active ports in each VLAN (access ports and trunks which permitted VLAN).
Try to type command "show spanning-tree" and if you count number of interfaces for each VLAN you will get number in show spanning-tree summary
05-31-2016 11:46 PM
