split off one subnet from default route path
logan-7
I have a subnet that I need to make sure goes to a different firewall than the rest of the traffic on my network. I have both firewalls on the same 6513(core router) and need to make sure that the specific traffic from one subnet goes to the other firewall ( for internet traffic) all the time.
Would Route-maps work for this.
thanks
andrew.andy316
Yes a route map could work for this situation.
could you give an example
thanks
Hi Logan,
Hope the following helps.
access-list 100 permit ip 1.1.1.0 0.0.0.255 any
route-map ISP1 permit 10
match ip address 100
set ip next-hop (ISP1 GW add here)
ip local policy route-map ISP1
