Split Outbound Data Traffic
I have hooked up to the Cisco 2821 router a T1 on Serial and Cable Modem to GigEth0/1 and I want to split outbound traffic so that all regular users will use G0/1 interface for web traffic and the rest of the traffic stays with the T1.  I am having an issue where the users on the network are not able to use the internet when using the following config:
interface GigabitEthernet0/0.10
description Data
encapsulation dot1Q 50
ip nat inside
ip virtual-reassembly
ip policy route-map policymap
interface GigabitEthernet0/0.20
description Voice
encapsulation dot1Q 60
ip address 172.20.10.1 255.255.255.0
ip nat inside
interface Service-Engine0/0
ip unnumbered GigabitEthernet0/0.20
ip nat inside
service-module ip address 172.20.10.2 255.255.255.0
service-module ip default-gateway 172.20.10.1
interface GigabitEthernet0/1
ip address 98.191.xx.xx 255.255.255.224  (ip address of new line)
ip access-group 111 in
ip nat outside
duplex auto
speed auto
access-list 111 permit tcp any any eq www
access-list 111 permit udp any any eq domain
route-map outside-nat permit 10
match ip address 100
match interface Serial0/0/0.501
route-map policymap permit 10
match ip address 111
set ip default next-hop 98.191.xx.xx  (gateway to ip from g0/1)
Please lend any assistance or ask any questions.  Thank you
David,
If you need to allow outbound dns, you'll want to also nat that traffic over the wan like you did for web traffic. You'll probably need to add:
access-list 101 permit udp 192.168.1.0 0.0.0.255 any eq 53
John
Please rate all helpful posts
HTH, John *** Please rate all useful posts ***
11 Replies 11
John Blakley
Can you post your nat configuration, and I notice that your acl on g0/1 is the same acl that your route-map policymap references. This may be because of your nat config....
ip nat inside source static tcp 172.20.10.2 80 interface Serial0/0/0.501 8080
ip nat inside source route-map outside-nat interface Serial0/0/0.501 overload
!!!!  below is for for smtp servers and outside data required server
ip nat inside source static 192.168.1.5 209.156.xx.xxx route-map outside-nat
ip nat inside source static 192.168.1.4 209.156.xx.xxx route-map outside-nat
Can you post your 100 acl?
here is the complete acl
access-list 10 permit 172.20.0.0 0.0.255.255
access-list 100 deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 100 deny   ip 172.20.0.0 0.0.255.255 192.168.0.0 0.0.255.255
access-list 100 deny   ip 172.20.0.0 0.0.255.255 172.20.0.0 0.0.255.255
access-list 100 permit ip 172.20.0.0 0.0.255.255 any
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
access-list 150 remark L2L IPSec Rule
access-list 150 permit ip 192.168.0.0 0.0.15.255 192.168.2.0 0.0.0.255
access-list 150 permit ip 172.20.0.0 0.0.255.255 192.168.2.0 0.0.0.255
access-list 190 remark Client IPSec Rule
access-list 190 permit ip 192.168.0.0 0.0.15.255 192.168.10.0 0.0.0.255
access-list 190 permit ip 172.20.0.0 0.0.255.255 192.168.10.0 0.0.0.255
access-list 199 permit esp any any
access-list 199 permit udp any host 209.156.xxx.xxx eq isakmp
access-list 199 permit udp any host 209.156.xxx.xxx eq non500-isakmp
access-list 199 permit tcp any host 209.156.xxx.xxx eq 22
access-list 199 permit tcp any host 209.156.xxx.xxx eq telnet
access-list 199 permit tcp any host 209.156.xxx.xxx eq 8080
access-list 199 permit tcp any host 209.156.xxx.xxx ack
access-list 199 permit tcp any host 209.156.xxx.xxx established
access-list 199 permit udp any eq domain host 209.156.xxx.xxx
access-list 199 permit tcp any host 209.156.xxx.xxx eq smtp
access-list 199 permit tcp any host 209.156.xxx.xxx eq 3389
access-list 199 permit tcp any host 209.156.xxx.xxx eq 443
access-list 199 permit tcp any host 209.156.xxx.xxx eq 143
access-list 199 permit icmp any any
access-list 199 deny   ip any any log
Based on your acl inbound, you're allowing traffic in on the interface that you're pushing your users through. Can you remove the acl to see if that fixes your issue? Otherwise, try putting this in your acl:
permit tcp any any established
I don't see a good reason for the acl to be applied inbound on your cable interface. All of your static natting points to your T1. I'd remove the acl completely from G0/1.
I also don't see you natting to the G0/1 interface in your nat statement, so try this:
access-list 101 permit tcp 192.168.1.0 0.0.0.255 any eq www
route-map WWWOnly permit 10
match ip address 101
ip nat inside source route-map WWWOnly interface g0/1 overload
When you say removing the ACL are you referring to just the 111?  Thank you
Yes...this line:
ip nat outside
duplex auto
speed auto
So the web traffic works with one major caveat, the DNS is not working which is sorta a big issue, all the systems use main server for DNS traffic (192.168.1.5) and here is the DNS in the IOS:
ip dhcp pool data
   network 172.20.0.0 255.255.255.0
   dns-server 66.155.216.122 207.59.153.242 66.251.35.130 68.105.29.16 68.105.28.16
   domain-name *.com
   default-router 172.20.0.1
ip domain name *.com
ip name-server 66.155.216.122
ip name-server 207.59.153.242
ip name-server 66.251.35.130
ip name-server 68.105.28.16
ip name-server 68.105.29.16
!!!! where the dns servers for the cable modem are the 68.xxx numbers and the rest are for the t1 circuit
Is this issue server related or something on the router?  i can ping on the router through both the t1 circuit g0/0.10 and through the cable modem circuit g0/1.  Again thank you for your help
David,
John
Worked like a charm and everything is up and running, thank you.
You're very welcome...glad to hear it, and thanks for the ratings!
