Splitting bandwidth between different hosts
Adeel Hasany
Hi All,
I have a situation where customer asked me to split 10 Mb WAN circuit to 6 Mb and 4 Mb for the hosts from the same subnet. There are two different departments and due to some reason we cant split them into two networks at this stage. Is there a possibility to allocate 6 Mb for 50 hosts and 4 Mb for remaining hosts from a /24 network?
Ad
Hello
Folllowing on from Joesph suggestion, See the below shaping example for 10MB egress traffic spilt between two classsfications.
access-list 100 permit ip 172.16.1.0 0.0.0.127 any
access-list 101 permit ip 172.16.1.128 0.0.0.127 any
class-map match-all Lowhost_cm
match access-group 100
class-map match-all Highhost_cm
match access-group 101
policy-map Shape_Child_pm
class Lowhost_cm
bandwidth remaining percent 60
class Highhost_cm
bandwidth remaining percent 40
class class-default
fair-queue
policy-map Shape_Parent_pm
class class-default
shape average 10240000 160000
service-policy Shape_Child_pm
interface x/x
Description WAN
service-policy output Shape_Parent_pm
res
Paul
Kind Regards
Paul
Hello
Can these hosts split between the subnet
ie: 50 host low end, 50 hosts high end or are they mixed
Or can they be split via specific application src / dst ports
if yes to any of these then it can be possible
res
paul
Kind Regards
Paul
Hi Paul,
Many thanks for your reply. cant split them up via specific application however, I can re address and divide the subnets. what will be your approach in this scenario?
Ad
Hello
class Lowhost_cm
class Highhost_cm
class class-default
fair-queue
class class-default
interface x/x
Description WAN
res
Paul
Kind Regards
Paul
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Usually, you can.  (What you can do also depends on the platform being used.)
For egress you might have the choice of policing or shaping.  For ingress, you cannot shape.  (Policing ingress might not provide the exact results you desire.)
Also, for egress, rather than setting hard bandwidth limits, you might be able to prioritize 3:2, that way, hosts can take advantage of otherwise unused bandwidth.
