I am trying to implement per tunnel QoS in DMVPN as per the document:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_dmvpn/configuration/15-mt/sec-conn-dmvpn-15-mt-book/sec-conn-dmvpn-per-tunnel-qos.html
Based on this document I believe that spoke-to-spoke QoS requires nhrp group attribute command. However, I am confused about the spoke-to-spoke QoS configuration.
The document illustrates under "Configuring an NHRP Group Attribute on a Spoke":
nhrp group attribute spoke1
But I don't see spoke1 being used elsewhere in that configuration part.
Whereas under "Example: Configuring an NHRP Group Attribute on a Spoke":
ip nhrp attribute group1
ip nhrp map group group1 service-policy output p2
I see that group1 has been used in the next command ip nhrp map..
Could anyone please guide me to know what exactly has to be done in order to enable QoS between spokes? I'd greatly appreciate that.
Qamber
